Is it possible to open the material library manager withoiut opening a model?
Solved by Andrew.Sartorelli. Go to Solution.
Hi Steve,
Yes, you can open up the material library manager from within Sim Mech without having a model open. Simply select the Tools tab from the Ribbon and click on Manage Material Library.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Or if you don't even want to open the Simulation Mechanical interface you can use mlibmgr.exe, located in C:\Program Files\Autodesk\Simulation 2015.
