Discussion Groups
Simulation Mechanical and Multiphysics
DonaldR.Culp7481
Material Library Manager: damping value - where is this used?
162 Views, 1 Replies
08-13-2013 06:55 PM
When I select a material in the Material Library Manager, "damping" is one of the available entries under General Properties. For what type of analysis would the material's damping be used?
Don C.
Please use plain text.
Employee
PipePakPat
Re: Material Library Manager: damping value - where is this used?
09-26-2013 02:01 PM in reply to: DonaldR.Culp7481
Hi Don,
This is material damping used in MES analyses.  Typically, this value is left as zero, unless physical testing has been performed to determine this value, then it is still very small, such as ~"0.05".  I think this correlates to "Tangential damping" is described in research articles I have previously read.
Just confirmation that it is best to leave as zero unless you know otherwise :-)
Pat
Pat Tessaro, P.E.
Customer Support Engineer
285 Kappa Drive
Suite 250
Pittsburgh, PA 15238
