I'm trying to use the Export > Make FEM command to generate a new model, but every time I try it, the program stops responding. I have tried it with a couple of different models and rebooted the computer, but nothing seems to help. I have let it run while not responding for up to 30 minutes. The primary model I am working with is not large (only about 86k nodes, and one applied surface force) and the analysis runs in under 5 minutes, so it would appear that something is not working properly with this command. Has anybody else run into this issue? If so, how was it fixed?
It does take a lot of time. I have also used the "Make FEM"-command on a model of about 40k nodes, and it could take up to 45 minutes. So there's nothing wrong with the command, it just takes ages.
