Simulation Mechanical and Multiphysics
Distinguished Contributor
1 Kudo
lumped masses
171 Views, 4 Replies
04-23-2012 12:02 PM
Hi
I am using  beam elements in one of my model.I am using setup--loads--weight to give the beam element its actual weight.
my question is, while defining  element definition and material, we do give c/s of the beam and density of the material.
so how does asim calculates the weight of the beam? Assigned weight or calculating the beam volume and multiplying with density or adding both?
your help is appreciated.
madg1
ASIMM 2012
Employee
8 Kudos
Re: lumped masses
04-24-2012 08:02 AM in reply to: madg1
I'm not very sure about this beam check, but my guess is setup-loads-weight is a kind of load, instead of changing mass/density.
If this response answers your concern, please mark it as "solved".
1 Kudo
Re: lumped masses
04-24-2012 08:09 AM in reply to: madg1
okay.
In my model I do have many beam elements with some elements having actual c/s properties. So ASIM can calculate weight from gravitational multiplier.
But for some other beam elements, I need to assign the weight manually.So I  use lumped masses.If asim also adds weight due to gravity, then it means adding up more weight to the beam elements right? or is there any other way around?
madg1
ASIMM 2012
Employee
43 Kudos
Re: lumped masses
04-24-2012 08:44 AM in reply to: madg1
The "weight" of a beam element equals "cross section area" x "length of element" x "mass density" x "Acceleration due to body force" x "X, Y, and Z multiplier" x "Gravity/Accel Load Case Multiplier". All of these values are entered by the user. The only one that you can make 0 without affecting the weight of the rest of the model is the mass density.
Note that the "Gravity/Accel Load Case Multiplier" is used if performing linear stress analysis. For MES and nonlinear analyses, the Load Curve is used in place of the "Gravity/Accel Load Case Multiplier".
Adding "Setup > Loads > Weight" (formerly known as lumped mass) to a model is adding additional weight. It is similar to adding a force or a distributed load.
Sincerely,
John Holtz, P.E.
Senior User Experience Designer, Simulation
Current version of Mechanical & Multiphysics: 2013 SP1 (2013.01.00.0012 28-Jun-2012)
1 Kudo
Re: lumped masses
04-24-2012 08:52 AM in reply to: INACTIVE_AstroJohn
then john do lumped masses addup in overall weight calculation.
I did find this in the ASIM 2013 wiki
Lumped masses and lumped mass moments of inertia may or may not be included in the weight and center of gravity calculation depending on the analysis type. Also, the results with masses of different values in the X, Y, and Z directions may be based on the X mass only. Refer to the weight and center of gravity summary file (.WCG) to see how it is treated for each situation.
madg1
ASIMM 2012
