Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Long simulation time
3 REPLIES 3
Dan_Margulius
982 Views, 3 Replies
Hello ,
I have this iphone cover wich I did a drop test on him for 2 seconds. The analysis took more then  10 HOURS!
Is this a reasonable runtime? I am working on workstation Dell M6300. I am attaching the part maybe someone can run the analysis at hus end and tell me how much time it takes.
Dan
3 REPLIES 3
S.LI
in reply to: Dan_Margulius
The simulation time really depends on your model setting, such as mesh size, material model, time step size etc.
All FEA related information doesn't show in your ipt file. Maybe you can put your log file here, ds.alg.
If this response answers your concern, please mark it as "solved".
Dan_Margulius
in reply to: S.LI
Hello ,
I am attaching the file you asked.
Thank you
S.LI
I think your mesh look ok.
My suggestions are
1.) changing the integration order from 3 to 2 by element definition dialog.
2.) replacing impact plane with general surface contact.
3.) after the above change, if everything works, you can use large step size to save unnecessary calculation and output.
