Discussion Groups
Simulation Mechanical and Multiphysics
Active Contributor
0 Kudos
Linear Heat Transfer from PV/Designer
130 Views, 1 Replies
08-25-2013 11:48 PM
Hi All!!!
I'm doing a linear heat transfer analysis...I started the model in PV/Designer....But when I'm changing the edit element definition...It does not accept...Can PV/Designer model be used for heat transfer analysis?...If not, are there work around to make it work?...
Many Thanks in advance for the help,
129 Kudos
Re: Linear Heat Transfer from PV/Designer
08-26-2013 06:45 AM in reply to: tibor121774
Hi Tibor,
It should not matter where the model comes from. So please give a complete description of the problem, maybe even a step-by-step description starting from the Element Definition, when the problem occurs, and what the problem is.
The answer to these questions may be helpful, too:
  1. What version of Simulation Mechanical are you using?
  2. What analysis type are you using?
  3. What element type are you using?
  4. Can you make changes to "Setup > Model Setup > Parameters"?
John Holtz, PE
Mechanical Engineer
Pittsburgh, PA
Simulation Mechanical user since Dec 1997
