We just got upgraded to 2014, for first two analysis the program ran well.
Later the Element definition can't be defined, so material also can't be defined.
see the picture below, all the red line in browser window are not defined (analysis type is also red)
please anyone help me to solve this issue
Solved by AstroJohnPE. Go to Solution.
Hi sriramsheval,
Assuming the usual things did not work, such as exiting the software and restarting it, rebooting the computer, and so on, my guess would be that the name of the model or one of the folders where the model resides is causing a problem. Make a really simple folder on your hard drive (such as C:\junk) and do a "File > Save As" in Simulation Mechanical. Place the model in the simple folder and name the model test.
Does this work?
