Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Is there a limitation to fatigue wizard?
2 REPLIES 2
bjorn_fallqvist
571 Views, 2 Replies
So far I have only been able to run fatigue wizard with reasonably small models. When I tried running a large model (about 800 000 DoF) I get an error saying "Out of memory". I have over 50GB free space and 32GB of RAM, so I don't see what it's complaining about. For somewhat smaller models (about 450 000 DoF) fatigue wizard simply does not start. Is there some kind of limitation on how big a model it can handle?
/Björn
2 REPLIES 2
I am running Algor Sim 2011 x64 edition and I get the same as what you described as well. I also have large memory and disk space. I ran small models successfully and then ran progressively larger models until FW does not start at all.
I hope the development team answers this question for us.
nosborne
in reply to: bjorn_fallqvist
I am using Simulation Mechanical 2012 and the fatigue wizard still works on a small model with 80000 DOF but will not run at all on a larger model with 154000 DOF. The models are both using linear static analysis results with similar settings - the only difference is the mesh is all tets in the larger model.
I get a "runtime error 6 - overflow" message".
Has anybody found a workaround for this issue???
