Solved by Sualp.Ozel. Go to Solution.
Take a look at the following web page link to see typical results you can get using Autodesk Simulation Mechanical when performing such analysis with "MES"
-Sualp
It would be just AMAZING if you can upload a tutorial on how to do that... (I mean the simulation showed in the link you provided http://www.applycon.com/Examples/06_Wheel_Deformation6.htm )
