Discussion Groups
Simulation Mechanical and Multiphysics
New Member
tcarrillo12
Impact Simulation on a Aluminum wheel.
601 Views, 3 Replies
02-10-2013 08:56 PM
I would like to simulate an impact test that's performed on aluminum wheels for an automobile as part of the evaluation for performance.
The wheel is tilted 13deg from a horizontal plane and mass of, let's say 1250 lb is dropped from a height of 9 inch. Please image attached.
Please use plain text.
Employee
zhuangs
Re: Impact Simulation on a Aluminum wheel.
02-14-2013 07:18 AM in reply to: tcarrillo12
You can use MES contact to simulate this impact problem.
-Shoubing
Employee
Sualp.Ozel
02-15-2013 06:28 AM in reply to: zhuangs
Take a look at the following web page link to see typical results you can get using Autodesk Simulation Mechanical when performing such analysis with "MES"
Impact Simulation on a Wheel
-Sualp
New Member
eaterac
03-30-2013 10:18 PM in reply to: Sualp.Ozel
It would be just AMAZING if you can upload a tutorial on how to do that... (I mean the simulation showed in the link you provided  http://www.applycon.com/Examples/06_Wheel_Deformation6.htm    )
