I'm trying to run an analysis for a quite large model, but I keep getting an "I/O error" message. That's all it says. In the log file it looks like this:
** STOP: I/O error!
What is this due to? It occurs after the very first iteration (it's a MES analysis).
Solved by S.LI. Go to Solution.
How large is your model? for examples, how many elements, equations, nodes?
It was around 1,5 million degrees of freedom (all brick elements). The problem disappeared when I reduced the number of elements...so I guess that's one way to solve it.
