Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
I found a bug when you run a Single Analysis with Multiple Load Cases
3 REPLIES 3
359 Views, 3 Replies
 I found a bug for Autodesk simulation multiphsics2013.
 When you used a Single Analysis with Multiple Load Cases, you will found the results were wrong from load case2 to the end.
 Did anyone meet this problem?
3 REPLIES 3
But the load case1 were reasonable.
And the analysis results haven't this problem when used previous versions.
AstroJohnPE
Hi everyone,
That bug was fixed in 2013 Service Pack 1 (SP1). The current version is service pack 2. So please update your software to the current version.
If I remember correctly, the multiple load case bug depended on the size of the model, so the results were not always incorrect.
in reply to: AstroJohnPE
Thanks for your help!
