Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
I can't install/run Multiphysics anymore, What to do?
2 REPLIES 2
1170 Views, 2 Replies
   My autodesk multiphysics doesn't run anymore. So I uninstall, and reinstall. Then I tried Simulation Mechancial 2014. But it doesn't work too.
   So I restore my computer, but it still doesn't work.
Strangely, Inventor works normally.
When I try open Simulation mechanical 2014 or Multiphysics 2012, a message telling I have no license appears.If I click "try", an error message appears. If I click register/sign in, it shows me a blank window.
    I use an academic version.
2 REPLIES 2
punisher
I have never run into this exactly, but once you've restored and reinstalled, with the same result, you're heading for a new OS install. Wish I could do more.
John Evans
Autodesk Certified Professional
http://designandmotion.net
Tags (1)
ehtesham.bokhari
uninstall both and restart your PC and install only one out of these two.
Both of these can't be install along with each other, there come some license issue. that came to me and then I uninstall both and installed Mechanical only.
But now I am facing problem again because I need
Fluid Flow
Mass transfer
simulations so I my self am trying to find some way.
Ehtesham Bokhari
PhD Student
COMSATS
Ehtesham Bokhari
PhD Student
Thermal and CFD Simulation Analysis
