Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Hyper-Threading Technology with 2012
9 REPLIES 9
Message 1 of 10
bannecke
8382 Views, 9 Replies
just a short question regarding the 2012 Version.
Is it still recommended to turn Hyper-Threading off for the best performance?
Regards
Boris
9 REPLIES 9
Message 2 of 10
S.LI
in reply to: bannecke
YES.
2012 and previous versions are enhanced by multi-thread tech, which has better performance with Hyper-threading off.
If this response answers your concern, please mark it as "solved".
Message 3 of 10
S.LI
in reply to: S.LI
PS:
Do you have any benchmark data for Hyper-threading on and off?
Thanks.
Message 4 of 10
bannecke
Me? No sorry.
I was just asking if it may be a good idea to switch HT on, because in the "new features" an improved multi core support was announced.
Anyway - thank you for the quick response.
Regards
Boris
Message 5 of 10
SaMurgie
It is still typically best to turn off hyper-threading with any compute intensive application such as Adsk Sim Mech.  While I have seen a couple of benchmarks that showed improvement, in most cases, the analysis takes longer.  The cases where HT actually helped were small MES models that had many, many time-steps.
Plus every release we are adding additional multi-core support.
I, too, recommend turning HT off.
Message 6 of 10
Dan_Margulius
How do i turn off HT ?
Dan
Message 7 of 10
bannecke
In your BIOS setting.
There should be a tree "advanced settings" or something similar.
You find the settings when you pres "del" or "F8" during the boot screen, depending on the manufacurer.
Message 8 of 10
Dan_Margulius
Thank you for the answer
Message 9 of 10
S.LI
I happend to have a simple 2012 benchmark about HT on/off.
HT on is around 40% slower than HT off.
My system is win7 64bit with Intel i7 12 cores (24 after HT on).
Message 10 of 10
guestpost66.3
in reply to: SaMurgie
your article is so informative and very helpful.
