Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
How to set path to material library?
1 REPLY 1
DonaldR.Culp7481
284 Views, 1 Reply
For Simulation Mechanical 2012, how can I set a path so that FEMPRO knows where to find a user-defined material library. For example, a path such as "G:\Autodesk\Materials". If this can't be done directly in FEMPRO, where else can the path be set?
Windows 7
Don C.
1 REPLY 1
Hi Don,
You should be able to use the "Tools > Options > Manage Material Library" command, then click the "Add" button to link and existing library to the software. You can add multiple libraries in different locations using the library manager.
