For Simulation Mechanical 2012, how can I set a path so that FEMPRO knows where to find a user-defined material library. For example, a path such as "G:\Autodesk\Materials". If this can't be done directly in FEMPRO, where else can the path be set?
Windows 7
Don C.
Hi Don,
You should be able to use the "Tools > Options > Manage Material Library" command, then click the "Add" button to link and existing library to the software. You can add multiple libraries in different locations using the library manager.
