Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
How to see when part breaks Non Linear Analysis
1 REPLY 1
thomas.decoppel
537 Views, 1 Reply
I am doing a Static Stress with Non Linear material models on a bar.
The dimensions are 10 x 10 x 100 mm.
The left side is totally fixed and on the right side there is a force of 50000 N.
I know that is to much, but my analysis parameters are set into 100 steps.
So I am trying to see when the bar breaks. I want to know at which step te bar can't handle the force any more.
Ohter settings are:
Von Mises with Isotropic hardening.
My material is:
So when I start the analysis, it goes to step 52.
Then the Von Mises stress is 284 N/mm²
So I want the know if the part broke or not, or did it already break.
What is the error that Autodesk Simulation Mechanical gives when the part breaks.
1 REPLY 1
Hi Thomas,
Simulation Mechanical does not calculate the breaking of parts. The stress can increase to infinity (in theory, usually not in a nonlinear analysis because something will happen numerically that prevents the analysis for reaching infinite stress).
It is your job, as the engineer, to decide what criteria means that a part will break. Is it when the calculated stress exceeds the ultimate strength? Is failure due to fatigue? Impact? Fracture?
