Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
How to Properly Input Bending Moment in Autodesk Simulation 2014
2 REPLIES 2
tibor121774
399 Views, 2 Replies
Hello all!
How to Properly Input Bending Moment in Autodesk Simulation 2014 (Plate and Shell Element) in Nozzle of a Vessel to get a good result?
Thanks and Best Regards,
2 REPLIES 2
AstroJohnPE
in reply to: tibor121774
Hi tibor,
You should elaborate on why you are asking the question. Without some more details about the problem, the model, the arrangement, what you are tryingto calculate, what you have already calculated, and so on, the answer to your question is "Setup > Loads > Moments".
I guess you could try to combine Cylindrical Local Coorinate Systems with your Moment Loads to apply it in the tangential axis, or whatever load directions that you intend.
Regards
Ilyas
