Simulation Mechanical can be installed to the same computer as ProE/Creo, and during the installation, an option will appear to run the "Pro/ENGINEER Installation Utility" which will place the Simulation menu within ProE/Creo. This menu allows geometry to be transferred directly from ProE/Creo to Simulation Mechanical.
For situations where ProE/Creo is installed to the network and not locally to the same computer as Simulation Mechanical, the option to run the "Pro/ENGINEER Installation Utility" will not be available from the "SimMechConfig.exe" as described in the documentation. This option is unavailable only because the local installation of ProE/Creo was not found, but we can work-around this limitation.
We can still run the "Pro/ENGINEER Installation Utility" manually from a command prompt and reference the ProE/Creo installation files from this wizard. When finished, the Simulation menu item will appear in ProE/Creo and models can be transferred directly from ProE/Creo to Simulation Mechanical.
Here are the steps required to run this installation wizard manually:
- Open a command prompt "As an administrator" on the workstation for which Simulation Mechanical was installed
- Type the following command:
- "C:\Program Files\Autodesk\Simulation 2015\Addins\CADProE.exe" /force "C:\Program Files\Autodesk\Simulation 2015"
- (Where "C:\Program Files\Autodesk\Simulation 2015" is the path to the Simulation Mechanical installation directory)
- Choose the <Enter> key on your keyboard then follow the prompts and select the ProE/Creo network installation files and finish the wizard.
Once this has been completed, the Simulation menu item should appear from within ProE/Creo and models can be transferred directly to Simulation Mechanical.
Some items to keep in mind are:
- Simulation Mechanical can open ProE/Creo files directly. So if this connection does not exist, the Part and Assembly files can still be opened from the File|Open dialog within Simulation Mechanical.
- The Simulation Mechanical files are written to the same directory as the originating files. So if the ProE/Creo files reside across the network, then the Simulation Mechanical files will be saved there as well. It will be required that read/write permissions exist for the user to access this directory for proper software functionality. Also, there will be a reduction in performance due to the burden of network connectivity. The fastest performance will occur when all files reside on the same workstation as the Simulation Mechanical software.
Pat Tessaro, P.E.
Premium Support Specialist – Simulation
6425 Living Place
Suite 100
Pittsburgh, PA 15206
