Hi
I want to view the result in any custom plane. But there are only 4 default plane result available as below:
By clicking the plane can be rotated but i want to pan them too.
Thanks in advance.
Solved by AstroJohnPE. Go to Solution.
You can use the command (probably called "Slice Planes" or something very similar) on the "Results Options" menu. Be sure to look for the command that lets you translate the plane along the k direction. (I don't have the software with me, so the terminology may be different than I remembers. I have faith that you can figure it out.)
Hi AstrojhonPe
Yes there is a option as slice plane but it is not movable . It can only be rotated. But i need to move it .
Thanks for your help
If you do not have these commands, then I suggest that you contact technical support.
Hello
Yes I have found it. It is working good but the problem is I have to rotate or translate it by draging the mouse curser but in this way i am not getting exactly the same plane which I want. Is their any system to input equetion of a plane or thee poins co-ordinate of a plane to fix the plane.
Thanks in advance
