Each time when I use MES module, the "forrtl: severe (157)" error message might appear randomly. Then restart current simulation again and again is the only way to get the final analysis result.
Unfortunately, I have one model that will shut down at the same time step, and can't be restart. The error messages list as follows:
Time Percent DT L Iter. Residual
1.010100 10.10 0.000050 1 2 4.2521E-04c
1.010150 10.15 0.000050 1 1 1.0000E+00
1.010150 10.15 0.000050 1 2 6.8008E-07c
1.010200 10.20 0.000050 1 1 1.0000E+00
1.010200 10.20 0.000050 1 2 6.7957E-07c
1.010250 10.25 0.000050 1 1 1.0000E+00
1.010250 10.25 0.000050 1 2 6.7924E-07c
1.010300 10.30 0.000050 1 1 1.0000E+00
1.010300 10.30 0.000050 1 2 6.7939E-07c
1.010350 10.35 0.000050 1 1 1.0000E+00
1.010350 10.35 0.000050 1 2 6.7980E-07c
1.010400 10.40 0.000050 1 1 1.0000E+00
1.010400 10.40 0.000050 1 2 6.8029E-07c
1.010450 10.45 0.000050 1 1 1.0000E+00
forrtl: severe (157): Program Exception - access violation
Image PC Routine Line Source
arun4.exe 00000001406896F6 E25LD9 904 xxzld5.for
arun4.exe 00000001401B2C95 YXE25LD5 25 psubrgd2.for
arun4.exe 00000001404BE843 YXFE3D 2638 fe3dmix.for
arun4.exe 000000014053CED6 FE3DM 411 xfe3d.for
arun4.exe 00000001404FB90B ELEMNT 87 zelemnt.for
arun4.exe 00000001403F3793 A_NONLIN 800 yassem.for
arun4.exe 00000001403EF9E1 ASSEM 173 yassem.for
arun4.exe 000000014038DCD1 MATREF0 194 ymatref.for
arun4.exe 0000000140407DC6 EQUIT4 241 xequit4.for
arun4.exe 00000001402943A3 NLLOOP 83 equilibr.for
arun4.exe 000000014060267C VSS_IMPL 655 vssimpl.for
arun4.exe 0000000140181989 FMAIN 614 yapak4.for
arun4.exe 000000014067116C MAIN__ 333 fallocn.for
arun4.exe 0000000140EDDEAC Unknown Unknown Unknown
arun4.exe 0000000140D4DE5F Unknown Unknown Unknown
kernel32.dll 0000000077D5964C Unknown Unknown Unknown
~~~~~~~~~~~~~~~~~~~~~~~~~ restart message ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
** Total available memory = 14860784 (KB).
** Options executed are:
NOMIN - NO optimization for matrix storage
RESUME - Resume an unfinished run
RUN - Execute processor
STRAIN - Output strain data for Superview
DUPLEX - Duplex communication with tWAIT=5 seconds
PRRO - Output reaction force data, n=2
PRCD - Output contact diagnostics data
** Reached autotm limit.
** For possible causes and solutions,
check under "Help: Index" for "Autotm limit".
** Job started : Time1
** Job finished : Time2
** Total elapsed time : 19 (seconds)
** Error (1)
!! Program aborted !
1.How to avoid and solve the error completely?
2.Is there any update program for this problem?
3.What might be the cause that I can not restart my simulation?
CCZ90
Software Edition: Algor23.1 , ASM 2012
OS: XP 64 SP2
PS: model upload is not available
According to your log file, the error happened during surface loads calculation.
I'm not sure the reason why it failed here.
One of the ways to avoid it is to replace surface force/pressure/traction with nodal forces.
Please consider to upload an alternative model if the error could be consistently re-produced there.
Thanks a lot.
The problem is converge if you read the help about Autotm limit the problem is that your model is not converging to a result. I have the same problem and I´m trying to find the best solver to find my convergence.
The log file shows that the time step is still at level 1. The might be a random error or a kind of crash.
Could we know which version is used?
-Shoubing
I am using mechanical simulation 2015 .im doing software evaluation at the moment. In my case i am doing a hydrostatic load over the wall of a tank to reproduce the deformation of the real tank
i have the problem in thermal and static transient. if i remove loads the model runs but with all my loads the model do not converge.
I'm going to ask for authorization to share the document.
