Discussion Groups
Simulation Mechanical and Multiphysics
Active Contributor
Sultan9009
Help with multiphysics
298 Views, 32 Replies
06-19-2012 05:47 PM
Hi I am Asif
I need help simulating, fluid flow through a porous medium. I created a solid cylinder in inventor with a inlet and outlet. The fluid I want to use to perform the simulation is air. I want to find the pressure on the porous medium, with a velocity of 20cm/min coming out the outlet. I having problems trying to simulate this scenario. I look at the tutorials provided, but it does not help. Can you please assist me with this task.
Please use plain text.
Employee
Joey.X
Re: Help with multiphysics
06-20-2012 08:23 AM in reply to: Sultan9009
Hi, Sultan9009
Here are steps for flow through porous media (combination of porous parts and regular fluid parts).
- In CAD modeling, set the porous material as part(or multiple parts), and push the CAD into simulation. Or read CAD assembly from SIMMP.
- In SIMMP/FEDEditor/tree view, select porous part(s), select element definition, under "general", change Viscosity model to "Porous media model"; under Orientation, set material model as Isotropic or Orthotropic, for orthotropic, the material axis etc. need to be specified.
-  In SIMMP/FEDEditor/tree view/porous part(s), right click Material, define porous material properties such as permeability, inertial coefficient etc.
Attached is a simple 2D planar model for your reference.
Jianhui Xie, Ph.D
Principal Engineer
MFG-Digital Simulation
Active Contributor
Sultan9009
06-20-2012 11:11 AM in reply to: Joey.X
Autodesk (R) Simulation Steady Fluid Flow
Version 2012.00.00.0163-W64/X64 04-Mar-2011
Copyright (c) 2011, Autodesk, Inc. All rights reserved.
    Date & Time         : 06-20-2012  14:01:54
    Input File          : E:\Reactor.ds_data\4\ds
    Command Line Options: -silent-x721724
    PROGRAM               VERSION: 201200000163
    Alg-win-x64.DLL       VERSION: 201200000163
    AlgConfig-win-x64.DLL VERSION: 201200000163
    Agsdb_ar-win-x64.DLL  VERSION: 201200000163
    AlgSolve.exe          VERSION: 201200000163
 **** Starting main program
 **** Model Unit System Settings:
       Unit System              : English (in)
       Force                    : lbf
       Length                   : in
       Time                     : s
       Temperature (Absolute)   : deg F (R)
       Thermal Energy           : in*lbf
       Voltage                  : V
       Current                  : A
       Electrical Resistance    : ohm
       Mass                     : lbf*s^2/in
 **** Memory dynamically allocated = 31042 KB (1% of physical memory)
 **** Generating coordinates
 **** Generating initial conditions
 **** Generating boundary conditions
 **** FEA information
      Model Dimension........................... =   3D model
      The number of nodes....................... =   18650
      The number of elements.................... =   56266
      The number of equations................... =   69384
 **** Segregated Scheme Data
      Select segregated scheme ................. =   T
      Solver for momentum equations ............ =   Automatic
      Solver for pressure equations ............ =   Automatic
      Velocity relaxation factor ............... =   7.000E-01
      Pressure relaxation factor ............... =   5.000E-01
      Inertial relaxation factor ............... =   1.000E+00
      Apply automatic adaptive parameter control =   T
      ID of Detect stagnation due to oscillation =   1
      The number of equations (U)............... =   16999
      The number of equations (V)............... =   16999
      The number of equations (W)............... =   16866
      The number of equations (P)............... =   18520
 **** Turbulence Model Data..................... =   Off
 **** Proceeding with Equal-Order Segregated Method
 **** ENTERING TIME LOOP
 Step                                        NonL. Solv. == Euclid L-2 Norm ==
 Intv  Step     Time   Percent    DT      L  Iter  Iter   R_Norm_V    R_Norm_P
    1     1  1.000E+00   0.00  1.000E+00  1          50   |R/F|u =  NaN
 **** Error: Divergence detected in iterative solver.
             Please try sparse solver.
Can you help me with this error?
Employee
Joey.X
06-20-2012 11:44 AM in reply to: Sultan9009
This error most probally came from improper model setting such as boundary conditions, could you share your model setups and mesh info?
You can also try sparse equation solver which is more robust bet less speedy than default iterative solver.
change it from parameters icon/solution/Formulation>>/segregated control/solver control/change "iterative" (2 entries) to BCSLIB-EXT.
Jianhui Xie, Ph.D
Principal Engineer
Active Contributor
Sultan9009
06-20-2012 12:06 PM in reply to: Joey.X
May I get your email because the file is too big to be posted?
Employee
Joey.X
06-20-2012 12:18 PM in reply to: Sultan9009
Could you put the whole archive model in dropbox or skydrive etc and share to my email?
my email: xjohnh@gmail.com
Jianhui Xie, Ph.D
Principal Engineer
Active Contributor
Sultan9009
06-20-2012 12:22 PM in reply to: Joey.X
I shared the model on dropbox
Employee
Joey.X
06-20-2012 12:33 PM in reply to: Sultan9009
have a quick look, the outlet surface can't have ioBC and pressure BC simultaneously, suggest to get rid of pressure BC and try it again.
Jianhui Xie, Ph.D
Principal Engineer
Active Contributor
Sultan9009
06-20-2012 12:38 PM in reply to: Joey.X
I am not sure of how to get rid of pressure B. Can you tell me how?
Employee
Joey.X
06-20-2012 12:43 PM in reply to: Joey.X
At design scenario 4, the model has veolcity BC at inlet surface,  inlet/out BC and pressure BC at outlet surface. the latter is redundant. It is suggested to delete pressure/traction BC by click "loads and constriant group", select pressure BC, right click to delete.
Jianhui Xie, Ph.D
Principal Engineer
