Hello. Tell please, whether I made everything correctly?
There is a pipe on which water flows. The pipe has the heater intended for heating of water. I want to learn what water temperature will be at the exit.
My steps:
1) I appointed to all objects materials.
2) I appointed boundary conditions.
3) I started calculation.
Whether I made everything correctly?
Solved by AstroJohnPE. Go to Solution.
Hi DenPopov,
I suggest that you ask your question on the Simulation CFD discussion group. You will find more people there that use Autodesk Simulation CFD than here in the Mechanical/Multiphysics discussion group.
Sorry. I created a subject in CFD forum - http://forums.autodesk.com/t5/Simulation-CFD/Heating-of-the-current-water/td-p/4653865
