I have a model that was translated to step from UG. I imported it with no problem into Fusion. But going from Fusion to Simulation, there are distortions. Please see if you can figure out a way to get this model translated porperly into Simulation.
Solved by John_Holtz. Go to Solution.
Before getting into the following, see if this cleans up the display: "View > Appearance > CAD Rendering Options". Try unchecking the "Faster rendering" option and lowering the tolerance from 70. (Try 50% and 30% for example.) After making a change, click the "Apply" button. Does this clear up the display?
Otherwise, can you please provide more details, such as an image of the model after importing into Autodesk Simulation? I tried your model on my system, and the model came in clean.
Nice job John! Worked great! You've certainly been there a while. I remember getting advice from you back in 96!
