Forum,
Please take a look at the following file; it is a 1/4-section of a skid assembly with x- and z-symmetry applied. I loaded that section with 162500 lbs (6.07 psi see 2nd screen shot for location of water weight/force).
My question is, if the total weight over the entire skid area shown is 650,000 lbs, should I have entered that value in the -Y instead of the 165000 lbs? Does Simulation treat that number as the whole or strictly as the weight/force applied to that quarter section?
Secondly, I chose brick elements for both the plate and beams (solid) with mesh settings at 15%. Are my results skewed with incorrect element type? After initial mesh, should I have changed the actual W12x96, W8x31 and L3x3x3/8 to beam then made the associative selections in element definitions?
I ran the test in 2 ways:
Regards and thank you for looking.
You should be good with the 1/4 load on 1/4 of the model.
The accuracy of the results depends on how the thickness of the "thin" sections are meshed. At a minimum you should have at least two elements thick in the "thin" sections. Displacements can be reasonably accurate with a lower mesh density, but the stresses could be significantly off if you are only one element thick.
The best approach to a satisfactoty mesh would be to perform a convergence study. Plot the peak stresses with your 15% mesh density, then with several tighter mesh densities (e.g. 10%, 7%). When the stress values vary by a few percentage points between mesh density runs (or by a value you deem acceptable based on your overall stress margins), your results should be acceptably accurate.
You could also mesh the assembly as plate elements and connect your I-beams to the floor with stiff beam elements.
Stefan
