I am having a problem with fatigue wizard. When I run it on one work station, which is Algor Simulation MES 2011 without SP1, it runs fine. But when running it on another work station, which has Algor Simulation Professional 2011, with SP1, there are lots of problems. No matter which material, load curve, etc. I choose, the results only display 1 cycle to failure.
Does anyone else have a similar problem?
Björn
Hi Björn,
Unluckily, I cannot reproduce the problem that you are facing. Basically we have few changing for Fatigue Wizard in SP1.
Could you please uninstall SP1 on the work station that has Algor Simulation Profession 2011 and try your fatigue analysis again? If this problem still exists, please repair or reinstall this PRO version.
Hope it helps.
Tim
Algor Simulation QA
