After installing Autodesk Algor 2011, I decided to try out the fatigue wizard. To do so, I created a shaft (quarter model) with symmetry and applied a traction load at one end to compare the safety factor with that of handbook solutions. I now do like this:
1. I enter material data in the fatigue wizard (stress-based), Rm 470MPa and Endurance limit 140MPa (at 1E6 cycles).
2. Calculate everything, with the Kf = 1 (since I have already modelled the stress concentration in the CAD-program).
The problem is that in MES, I get safety factors of 10 for ALL nodes that fatigue wizard lists. Now, if I do the exact same thing in a linear static stress analysis, the results are a lot more reasonable (safety factor around 2, approximately the same as with handbook solutions). Is fatigue wizard not compatible with MES solutions? Should it not just use the element stresses and strains to calculate the fatigue life, regardless of analysis type?
Best regards,
Björn
