is there a way to generate external fluid around multiple parts?
I have a two part assy and external fluid only generates surfaces around Part 1.
I will combine the parts if necessary, but I couldn't find this limitation mentioned anywhere.
Hey,
Maybe you can provide a picture of the situation.
You can also model the air in the CAD environment and tell Algor that this solid is actually air or some other gas.
R.
Dan
Sorry, no pic. Away from machine. But imagine two blocks with a space between them.
I've done a workaround for the work at hand already.
I guess I'd just like to know if Algor is able to generate fluid around more than one part. Want to understand any limitations going forward.
