Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
external fluid generation and multiple parts
2 REPLIES 2
bbritcher
371 Views, 2 Replies
is there a way to generate external fluid around multiple parts?
I have a two part assy and external fluid only generates surfaces around Part 1.
I will combine the parts if necessary, but I couldn't find this limitation mentioned anywhere.
2 REPLIES 2
Dan_Margulius
in reply to: bbritcher
Hey,
Maybe you can provide a picture of the situation.
You can also model the air in the CAD environment and tell Algor that this solid is actually air or some other gas.
R.
Dan
bbritcher
in reply to: Dan_Margulius
Sorry, no pic.  Away from machine.  But imagine two blocks with a space between them.
I've done a workaround for the work at hand already.
I guess I'd just like to know if Algor is able to generate fluid around more than one part.  Want to understand any limitations going forward.
