Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Exporting summary file
3 REPLIES 3
9msl1
337 Views, 3 Replies
Hello
I'm running a rather long simulation file and need to access the results via the summary file of the report.
Is there a way to export the summary into a .txt file or some other format automatically?  The summary is so large that  my computer lags trying to access it
Cheers!
3 REPLIES 3
Stefan2653
in reply to: 9msl1
I'm not sure about exporting the summary file, but you can access the file from your model directory. If you go to the directory where your .fem file is located, go into the "xxx.ds_data" folder (xxx being your model name). Then go into the folder number that corresponds to your analysis case, where you should see about a dozen files. I don't know what type of analysis you have run, but for random vibration the summary file will be the xxx.l7 file, and the log file will be the ***.lg7. You can open both of those with a text editor. If you don't have those exact file extensions, you can just try opening any of the files, and you should be able to find the summary.
Stefan
9msl1
in reply to: 9msl1
Hello
I ran a frequency response analysis
Thanks again
Stefan2653
in reply to: 9msl1
Ok, your summary file should be ***.l5 and the log file should be ***.lg5.
Stefan
