I try to export a RFI-File to use it in RecurDyn. A simple model without any constraints or joint works. But if i try to generate more than one rigid element (face to node), an export is not possible --> System answer: Failure!
The reason why i need the two rigid elements is the requirement in RecurDyn to couple other bodies with the imported RFlex- Body.
What's the problem? Isn't it possible to export models with more than one rigid element? In this case this function would be doting.
Is somebody here who no better?
Hi Ceble,
Current the Simulation Mechanical to RecurDyn export function does not support line or planar elements, which would include rigid elements. You can read more about the RecurDyn interoperability on the Simulation Mechanical 2015 help site.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
thank you for answering quickly.
I acctually can't understand why it works with one rigid element when it's not supported at the moment.
What can I do with RFIs in RecurDyn when there is no possibility to connect them to other parts?
are there any more support of exporting to RecurDyn from Autodesk simlation tools? I don't see RecurDyn listed on the partners page. The only two companies i see that sell RecurDyn don't show anything Autodesk:
https://enginsoftusa.com/RecurDynMBD/Flexible-Multibody-Dynamics-with-Recurdyn.html
Hi @ceble
I was able to export a natural frequency model that had two rigid elements (2 parts).
Can you create an archive of your model ("app button > Archive > Create") and attach the .ach file to the forum? Also indicate what result you had displayed when trying to create the RFI file.
