Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Export Mesh Nodes To Text File
2 REPLIES 2
scudelari
541 Views, 2 Replies
Hello Everyone,
Is there a way to export the mesh nodes (X,Y,Z) to a text file?
I am setting up a non linear analysis and need to insert a radial force at an edge. If I use the standard way, which would be to change the coordinate system, the model does not converge.
Therefore, I'd like to use the loads from file functionality.
2 REPLIES 2
AstroJohnPE
in reply to: scudelari
The only place that nodal coordinates are shown in when you select the nodes in the Results environment, right-click, and choose "Inquire Results". You can then save the "results" to a text file.
scudelari
in reply to: AstroJohnPE
I though that would be the only way. Not so much of a table format, though.
Regex is the answer then...
