Discussion Groups
Simulation Mechanical and Multiphysics
Distinguished Contributor
4 Kudos
Export Mesh Nodes To Text File
181 Views, 2 Replies
11-28-2013 05:10 AM
Hello Everyone,
Is there a way to export the mesh nodes (X,Y,Z) to a text file?
I am setting up a non linear analysis and need to insert a radial force at an edge. If I use the standard way, which would be to change the coordinate system, the model does not converge.
Therefore, I'd like to use the loads from file functionality.
129 Kudos
Re: Export Mesh Nodes To Text File
12-01-2013 11:36 AM in reply to: scudelari
The only place that nodal coordinates are shown in when you select the nodes in the Results environment, right-click, and choose "Inquire Results". You can then save the "results" to a text file.
John Holtz, PE
Mechanical Engineer
Pittsburgh, PA
Simulation Mechanical user since Dec 1997
4 Kudos
12-01-2013 11:39 AM in reply to: AstroJohnPE
I though that would be the only way. Not so much of a table format, though.
Regex is the answer then...
