Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Message 1 of 11
mprearo
484 Views, 10 Replies
Error
Good afternoon,
I cannot solve this error; i also see on this internet page
http://wikihelp.autodesk.com/Autodesk_Simulation/enu/2012/Help/0220-Setting_220/0496-Set_Up_A496/050...
but i didn't find the solution.
Thank you in advance
Best regards
Manuel
10 REPLIES 10
Message 2 of 11
S.LI
in reply to: mprearo
See the attached file.
Do you set these beam cross-section properties?
If this response answers your concern, please mark it as "solved".
Message 3 of 11
mprearo
in reply to: S.LI
No, i don't.
Can you explain me this concept???I don't know what is beam cross-section properties; i'm trying to learn to use this software by myself and several tutorial.I'm an Algor beginner.
This error is due to the algor bolt, isn'it?
Best regards
Manuel
Message 4 of 11
S.LI
Beam element in FEA is a one-dimension element. All detailed cross-section information (round, I-shape, c-shape) does NOT exist in FEA formulation explicitly. But it's definitely necessary.
the attachment in my last post shows a simple example on how to set them. For fully details, you'd better go to search "beam/crosssection" in help file.
To simulate bolts, round cross section should be good enough.
Message 5 of 11
mprearo
in reply to: S.LI
I follow your suggest
thanks a lot
Message 6 of 11
John_Holtz
Hi Manuel,
I can see that Part 3 has an element type of beam. This is what the error message is related to. (The solver does not know, nor does it care, that you want to think of part 3 as "bolts". It only sees the element type Smiley Wink.) Edit the element definition (Definizione Dell Elemento) and make sure that the following cross-section properties are defined:
  • A = area
  • J1 = torsional constant (relates the angle of twist due to a torque load)
  • I2, I3 = area moment of inertia about the 2 and 3 axes.
The other properties (S2, S3, Sa2, and Sa3) can be 0.
I think S.Li was trying to demonstrate that if you click in the row for the beam cross-section properties (probably Layer 1), you can then click the "Cross-Section Libraries". From there, you can choose "User-Defined" and pick "Round". By entering the radius, the software will calculate the cross sectional values. (Just to complete the discussion, the library also has many of the AISC cross-sections, such as W beams, channels, and so on.)
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
Message 7 of 11
mprearo
in reply to: John_Holtz
Thanks a lot John. I don't know what will I do without you.
If i undestrand well the solver recognize only the type of element that, in the bolt case, is a beam; so the software created a beam in a FEA environment but it doesn't set the feature/properties. isn't it?
I'm used to generate bolt in Inventor and that software make each features by itself.
Thanks again
Have a good weekend
Message 8 of 11
mprearo
Last question.
I do this simulation to see the effects on the plat by the applied force on the shaft.
The result, in my opinion, is wrong because it's impossible that the strain is concetrated only in the application point of nodal force.
What's your opinion???
Message 9 of 11
S.LI
It's possible that high stress appears at specific points, such as loading points, constrain points.
If the load in your case is not a point-force, you can try to split it into several, and apply them on multiple nodes. Or you can choose surface force instead of nodal force.
This really depends on your case.
Message 10 of 11
mprearo
Thanks for your help.
I follow your suggest by applying a " surface force " and the software return me an expected result.
Is there a reason that Algor produce the previous nodal result??? is better that everytime i'll use a surface force than a nodal force???
Thnak you in advance
Have a good weekend
Manuel
Message 11 of 11
S.LI
Compared with a surface load, a nodal load could generate kind of concentrated stress response. This sounds pretty reasonable and fair, since a surface load is a kind of distributed load.
Basically, both loads should generate similar results at places FAR away from the loading position.
In another word, the effect of how to apply a load should reduce dramatically with distance.
