good evening analysts,
can anybody tell me if this error message says which beam element (each beam is in its own part) is bad? thanks.
flyboy2160
fem2esh - Make esh file from fem file
Version 23.01.00.0136-W64/X6405-FEB-2009
Copyright (c) 2009, ALGOR, Inc. All rights reserved.
Version of
fem2esh.exe : 23.01000136
Version of dcx1-win-x64.dll : 23.01000136
Version of
femapi-win-x64.dll : 23.01000136
Version of
agsdb_ar-win-x64.dll : 23.00000132
Version of
tsx2tsy.exe : 23.01000136
Input Model : C:\Users\flyboy2160\Documents\ALGOR 7-3-2011sq boom - all parts with
error\fus tubes 4 algor.ds_data\2\ds
Input File : C:\Users\flyboy2160\Documents\ALGOR 7-3-2011sq boom - all parts with
error\fus tubes 4 algor.fem
Output File : C:\Users\flyboy2160\Documents\ALGOR 7-3-2011sq boom - all parts with error\fus
tubes 4 algor.ds_data\2\ds.mod\group.esh
Log File : C:\Users\flyboy2160\Documents\ALGOR 7-3-2011sq boom - all parts with
error\fus tubes 4 algor.ds_data\2\ds.mod\group.ldx
Design scenario : 2
Analysis type : Linear Stress
Start time : 2011/07/03-19:39:57
--- Get 435 active
element parts in range [1, 737] from fem file
--- 47 enabled
L&C groups are defined
--- Get 1315 points
defined in range [1, 1781] from fem file
Calling the Surface
Topology Generator (tsx2tsy)...
tsx2tsy: re-made
part surface contact/bonding data (duration=1 sec.)
--- No mid-side node
required
Set up FEM points
and B.C. by connected elements...
In working on FEM
file or outputtingESH file
Terminal Error: FEM2ESH#19,
item#2
Wrong beam element
or illegal orientation
The error message states, "Terminal Error: FEM2ESH#19,
item#2", which suggests part number 19 experiences an error on the second item. It this item is a line from a beam element part, then I would suggest to display the number 2 axis direction on the beam elements in the FEA Editor to ensure these are not collinear (or close to it).
