Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Error when using MR-membrane elements
3 REPLIES 3
517 Views, 3 Replies
When I'm trying to use a 2-constant MR-model for my hyperelastic material model, I get the following error message:
Error encountered in subroutine                           CshTGE
 Error defining element coordinate frame, check element geometry, element=  308
I have tried running the model with a regular isotropic model instead, and then it works fine. Do you have any suggestions as to what might be wrong?
Björn
3 REPLIES 3
I also get this error message below the one above:
" ** Error: Part (3) requires more memory than available. Please reduce the part size
    by splitting it to several smaller parts"
That is ridicolous. The part it refers to is very small, a hundred solid elements at most, and I have tried splitting it but still keep receiving the same error message. What is wrong here?
Björn
zhuangs
Hi Björn,
Could you share your model for investigation?
Shoubing
in reply to: zhuangs
Hi, Zhuang
I have deleted this particular model, but the next time I encounter it, I will be sure to do so.
Björn
