When I'm trying to use a 2-constant MR-model for my hyperelastic material model, I get the following error message:
Error encountered in subroutine CshTGE
Error defining element coordinate frame, check element geometry, element= 308
I have tried running the model with a regular isotropic model instead, and then it works fine. Do you have any suggestions as to what might be wrong?
Björn
I also get this error message below the one above:
" ** Error: Part (3) requires more memory than available. Please reduce the part size
by splitting it to several smaller parts"
That is ridicolous. The part it refers to is very small, a hundred solid elements at most, and I have tried splitting it but still keep receiving the same error message. What is wrong here?
Björn
Hi, Zhuang
I have deleted this particular model, but the next time I encounter it, I will be sure to do so.
Björn
