Discussion Groups
Simulation Mechanical and Multiphysics
Active Contributor
SteveKS
Error when taking any action
164 Views, 2 Replies
11-20-2012 06:45 AM
When loading a part or taking an action like meshing or changing material, a "setup" pop-up comes up for 20 seconds before the action is performed. See the attachment for a png of the pop-up. The pop-up "loads" and then comes back a half dozen times before finishing. It does not seem to be performing any meaningful action. I cannot tie this error to any action I took with changing/updating the program, but it just started happening a week ago.
Using Simulation Mechanical 2013
Please use plain text.
Valued Mentor
AstroJohnPE
Re: Error when taking any action
11-21-2012 08:34 AM in reply to: SteveKS
Hi Steve,
Some other software probably got installed -- either by you, your IT department, or Windows -- and caused some type of conflict. I suggest using the Windows Control Panel to repair the installation.
John Holtz, PE
Mechanical Engineer
Pittsburgh, PA
16 years experience with Simulation Mechanical
Active Contributor
SteveKS
11-21-2012 12:09 PM in reply to: AstroJohnPE
A repair installation did not solve the problem, but reinstalling the program did. Thanks for the suggestion.
