Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Error when Contact then Separation
0 REPLIES 0
Message 1 of 1
groves174
266 Views, 0 Replies
Autodesk Simulation 2013 Mechanical - MES with Non-Linear Materials
I have two rods with an initial gap. A pressure function pushes one rod into the other, both are axially free to displace. The first rod is limited in it's motion by a collar. When Rod 1 stops moving by the collar, Rod 2 carries on.
The whole simulation works great until they separate. I get an astronomically high stress in the contact surfaces when they separate. (very simple, 2 flat surfaces at the end of the rods) It's like they were stuck together, but they do separate.
The contact pair is:
High Speed Contact
Frictionless Contact
Automatic Contact type
The 'No Bounce' box is checked but greyed out. There doesn't seem to be any way to un-grey it. I'm not sure if that's my issue. I've tried altering/refining the mesh to no avail
Ideas?
0 REPLIES 0
