Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Error message: Node number <1 found in element
1 REPLY 1
433 Views, 1 Reply
Hello
Has anyone come across this error in Simulation? What would cause such an error?
-Gaurav Suri
 **** PRINT OF TYPE-6 ELEMENT DATA SUPPRESSED
      error: node number < 1 found in element             3568
1 REPLY 1
S.LI
From your message, what I can tell is there is a plate part in your Linear model (LSS or others). In this plate part, some mesh or element connectivity was not generated all right for element 3568.
I cannot tell why here.
Maybe you should remesh your model, at least that part, to see if the same error message appears.
If this response answers your concern, please mark it as "solved".
