Discussion Groups
Simulation Mechanical and Multiphysics
amatsuda
Error from "ndxmap.exe"
94 Views, 2 Replies
10-02-2013 07:41 PM
Hello. We perform a thermal-stress analysis. As a first step, a thermal analysis can be done well. This analysis result is in a "Design scenario 1". Next step, we try to perform a static-stress analysis by using thermal distribution of "Design scenario 1".  "Node Mapping" error occured (pls. see attached fig1). How to resolve this issue?
A part of the ds_ndxmap.log is following; Number of parts is 83, Number of nodes are 465653/470104.  "Ndxmap.exe" has a model size limitation?
Best regars,
--------------------------------------------quote-----------
** Mapping type detection
-- Linear stress (LSS) reads thermal
Model Unit Comparsion Source Model Target Model
Length unit ........................................ Millimeter Millimeter
Time unit .......................................... Second Second
Temperature unit ................................... Celsius Celsius
** Build Part Mapping(Src/Tgt part#=83/83).......... 0.001 seconds
** Global Src/Tgt Node mapping(Node#=465653/470104)
Please use plain text.
*Expert Elite*
AstroJohnPE
Re: Error from "ndxmap.exe"
10-03-2013 02:24 PM in reply to: amatsuda
I do not know if this is the problem and solution, but it is something to try. My suspicion is a character in one of the paths from the root drive (C:\) all the way through the folders to where the analysis model is located (C:\...\...\my model.ds_data\2\ds.mod\).
Save the model to a short, simple folder name such as "C:\temp\try this.fem".
John Holtz, PE
Mechanical Engineer
Pittsburgh, PA
16 years experience with Simulation Mechanical
amatsuda
10-04-2013 04:38 PM in reply to: AstroJohnPE
Hi, John
Thanks for your suggestion. I moved a "mytry.fem" file and "mytry.ds_data" folder into "C:\temp".  But I got same error and analysis was terminated.... After that, mesh size was a little bit changed (in static-stress analysis), the analysis is now available. It seems like that my issue depends on mesh conditions.
Best regards,
Akihiro Matsuda
CAE Solutions Corp.
