Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Error during uninstall
3 REPLIES 3
435 Views, 3 Replies
Good evening,
i'm trying to unistall Algor 2011, cause my licenes is expired, but it always appearing an error message that it stop the unistalling sequence.
How i have to do???
The error messages is attached
Thank you in advance
Best regards
Manuel
3 REPLIES 3
S.LI
No clue on your issue.
Maybe you can go to installation/license groups for this question.
If this response answers your concern, please mark it as "solved".
Joey.X
in reply to: S.LI
Refer to this
http://forums.autodesk.com/t5/Autodesk-Simulation/Autodesk-Simulation/td-p/3001624/page/2
Message 13/16 to 16/16
Jianhui Xie, Ph.D
Principal Engineer
MFG-Digital Simulation
TravisNave
To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
http://support.microsoft.com/mats/Program_Install_and_Uninstall
For more information on the Autodesk KB Support article concerning the clean uninstall of Autdoesk products, see this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
For all other installation problems on Windows XP SP2 or below consider using the Microsoft Installer Clean Up Utility. For more information on this program, please my forum post here:
http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Re...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
