Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Error : could not allocate memory for linear stiffness
2 REPLIES 2
479 Views, 2 Replies
Hi
I get an error when i perform a MES analysis. This error is "Error : could not allocate memory for linear stiffness ".
Where could the problem come from?
Regards
2 REPLIES 2
Andrew.Sartorelli
Hi Polo76,
I recommend that you switch the solver from AMG-Iterative solver to the Sparse solver. This can be done in Analysis Parameters, go to Advanced > Other  and then change the "Type of solver" field from Automatic to Sparse.
Andrew
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Andrew Sartorelli - Autodesk GmbH
in reply to: Andrew.Sartorelli
Thanks Andrew
Regards
