Hi
I get an error when i perform a MES analysis. This error is "Error : could not allocate memory for linear stiffness ".
Where could the problem come from?
Regards
Solved by Andrew.Sartorelli. Go to Solution.
Hi Polo76,
I recommend that you switch the solver from AMG-Iterative solver to the Sparse solver. This can be done in Analysis Parameters, go to Advanced > Other and then change the "Type of solver" field from Automatic to Sparse.
Andrew
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
