Hi there, Does anyone know how to solve the error:
0x13C5: The analysis type set for the model is invalid or not recoginzed by Superview.
Im working on a tutorial file. Building, sending to server, and downloading worked fine, but it wont open the results.
Any idea how to fix this? Theres no way of doing a local solve, just server (so Im kind of stuck)
Thanks!
0x13C5: The analysis type set for the model is invalid or not recoginzed by Superview in the model,but before is running with check model funtion.
How I can fix it?
Pablo.
Hi Pablo,
It sounds to me as if some file is locked or not opening properly after performing the analysis. Can you try to exit the software, start it again, and open the model? Are you able to view the results doing that?
What version of Simulation Mechanical are you using?
If the model is small, you can create an archive of the model and results ("App button > Archive > Create") and attach the archive file (the .ACH file). That would let us look at the files to help determine the problem. If the archive file is large, can you reproduce the problem with a smaller test model? (I am not sure what size attachments the forum will accept.)
thank you for you help, but the model is running well in the linear static, but I don't know how fix for running with nonlinear analisys.
The way to fix the problem is to answer the questions so that we have more details about the problem.
the software is Autodesk Simulation Mechanical 2016.
When I run the check model I get this results, please see the atach.
Hi @pariasYJEV7
I do not see any warnings or errors in the text file, so my guess is that the model is shown in the Results environment when you do a "Check Model", and therefore you can view the results that were computed.
Is that correct?
I do have two suggestions:
