Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
element forces and moments for bolts
1 REPLY 1
craigbrockman3028
466 Views, 1 Reply
"Beginner alert"
All, When I create my model with (8) hold down bolts using the bolt wizard in release 2012.
After I have run my DDAM analysis, when I search the results, should I consider the results of the element forces and moments (axial force, local 2 and local 3) menu for the bolt stresses, or as my previous instruction to use the Results/Stress/Beam and Truss/ Axial (local 1), Bending stress (local 2, and bending stress (local 3) menu item.
I ask this because  the second menu item always shows vlues 2-3 time more than the first menu item.
Also, will the values of stress be differant when using 8 spokes vs 12 spokes.
Thanks in advance.
1 REPLY 1
I see that your question was also posted again.  Please refer to the following link in regard to this issue:
http://forums.autodesk.com/t5/Autodesk-Simulation/DDAM-AND-Bolts/td-p/3485346
Pat Tessaro, P.E.
Premium Support Specialist – Simulation
Autodesk, Inc.
6425 Living Place
Suite 100
Pittsburgh, PA 15206
