Discussion Groups
Simulation Mechanical and Multiphysics
New Member
Matthias_H
Accepted Solution
element excavation and installation
112 Views, 1 Replies
08-06-2012 07:03 AM
I'd like to use ASIM to model geotechnical buildings/tunnels. To this end excavation (removal of continuum elements) and installation of (beam, shell) elements at different time steps are important. Is this possible with ASIM?
Matthias
Please use plain text.
Product Support
PipePakPat
Re: element excavation and installation
08-09-2012 10:43 AM in reply to: Matthias_H
One cannot add or remove elements from an Autodesk Simulation Mechanical or Multiphysics (Algor) analysis once the analysis has been initiated.  So the model would have to be created and analyzed with the material already removed.  The available material models are Curve with cut-off, Drucker-Prager and Duncan-Chang.
Pat Tessaro, P.E.
Customer Support Engineer
Autodesk, Inc.
285 Kappa Drive
Suite 250
Pittsburgh, PA 15238
