Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
ralphgilstrap
298 Views, 1 Reply
Edit material
Unable to edit material or element definition
1 REPLY 1
AstroJohnPE
in reply to: ralphgilstrap
  1. Why not? Do you get a message that would give us a hint if you supply the text of the message? Is there no indication of a problem other than nothing happening?
  2. What is the analysis type?
  3. What element type is set?
  4. Are you editing one part at a time or multiple parts?
  5. What version of the software are you using?
  6. Can you edit the analysis parameters? ("Setup > Model Setup > Parameters"?
  7. Does it work after rebooting the computer?
