Hi all
I’ve been asked to investigate modelling the accelerations and loading during the launch of recovery of a large Rhib from either a single or dual point davit or rail system, suspended by cables, mounted on the side of a ship. The focus of the study is to evaluate the loadings and accelerations on the hook points and the effects on the occupants of the crew due to the resulting motions.
The simple model would consist of a full evolution of picking up the craft with the davit and lowering it roughly 10-15m out and over the ship’s side, followed by it hitting the water and the hooks automatically releasing.
I have the following questions:
I understand Inventor/Simulation’s purpose is quite different to what I want out of them but hopefully it would be sufficient for a simple model. If anyone could think of better software that would be much appreciated.
Alex
Solved by John_Holtz. Go to Solution.
Hi Alex,
I think I understand the general goal (lowering a small boat, the Rhib, overboard) without understanding all of the details (what's a davit? what's an Rhib?), but the software you should be looking at is Autodesk Simulation Mechanical, and the analysis type would be Mechanical Event Simulation (MES). MES is a dynamic solution (think F=m*a) of nonlinear models (large displacement, nonlinear materials, nonlinear elements like cables). Of the things that you described, here's what can be done in MES:
I do not know how you would be able to analyze these aspects, but maybe someone else has some ideas:
Ship ahoy, matey! I'm feeling sea sick already.
I received an email notification which shows that Alex posted another reply, but it does not appear when I look at the thread. The link in the email that should open the post causes an "unexpected error", so it is either a glych in the system or just for me.
The basic question is whether Simulation includes the ability to create models, or does it need a modeler like Inventor.
The answer is that Simulation does include its own modeling capability. You can either model directly in the software, or use Autodesk Inventor Fusion which is provided as a free add-on in the Simulation installer. Fusion is a 3D solid modeler, similar to Inventor, but different as well. The complexity or simplicity of the model will determine if it is easier to model within Simulation, or whether a model should be imported.
By the way, Simulation can read solid models from many applications (Inventor, Pro/E, SolidWorks, etc), surface models from some of the CAD apps, and wireframe "models or drawings" from AutoCAD and wireframe IGS.
