Hi everybody,
I have a problem with defining dynamic loads to Autodesk Simulation Multiphysics 2012. I have to define different loads changing by time. I attached a picture of the load curve. Can someone suggest me an idea?
Thanks for your replies.
Solved by S.LI. Go to Solution.
If you are using MES, you can import these data directly as MES load curves.
